PCPartPicker Part List
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($153.00 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler  ($36.99 @ Newegg)
Motherboard: Gigabyte Z790 AORUS ELITE AX ATX LGA1700 Motherboard  ($239.99 @ Amazon)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory  ($104.99 @ Amazon)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($129.99 @ Adorama)
Video Card: MSI GeForce RTX 3060 Ventus 2X 12G GeForce RTX 3060 12GB 12 GB Video Card  ($269.99 @ Amazon)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($79.98 @ Amazon)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($96.99 @ Newegg)
Operating System: Microsoft Windows 11 Home OEM - DVD 64-bit  ($121.98 @ Other World Computing)
Total: $1233.90
Generated by PCPartPicker 2023-11-19 18:14 EST-0500
can someone please tell me if this is good for gaming/streaming and video editing as im new to computers. also give suggestions such as make sure you get at least x sticks of ram. also if someone could link a cooling system that is dead silent and still extremely effective that would be much appreciated. also please point out if im missing anything that would be useful such as thermal paste or an ssd card
https://linustechtips.com/topic/1541860-pc-build-im-considering/
What's your budget? Something like this would take you miles ahead for not that much extra.
Buy windows key from a reseller. Only real very rare downside is you can't transfer the key to a new PC when you build it in the future. Have a look:
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($369.00 @ Amazon)
CPU Cooler: Thermalright Silver Soul 135 82 CFM CPU Cooler  ($34.90 @ Amazon)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  ($109.99 @ Amazon)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  ($99.99 @ Newegg)
Memory: TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-5600 CL32 Memory  ($79.98 @ Amazon)
Storage: Crucial P3 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($67.99 @ B&H)
Video Card: Zotac Twin Edge GeForce RTX 4070 12 GB Video Card  ($514.99 @ Newegg)
Case: Cougar MX331 MESH-X ATX Mid Tower Case  ($46.99 @ Amazon)
Power Supply: Corsair CX750M (2021) 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($74.98 @ Amazon)
Operating System: Microsoft Windows 11 Home OEM - DVD 64-bit  ($25.00)
Total: $1423.81
Generated by PCPartPicker 2023-11-19 19:14 EST-0500
If your max budget is near that mid $1.2k mark then get something like this instead:
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($199.00 @ Amazon)
CPU Cooler: Thermalright Burst Assassin ARGB 66.17 CFM CPU Cooler  ($23.90 @ Amazon)
Total: $1242.81
Generated by PCPartPicker 2023-11-19 19:17 EST-0500
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
Btw thermal paste should come preapplied with cooler you buy. No need to buy extra unless you smear it all over till there's none left.
so earlier i posted my pc build here and got some very useful suggestions so I revised my build and would like it looked at again
Motherboard: Asus ROG STRIX B650-A GAMING WIFI ATX AM5 Motherboard  ($219.99 @ Newegg)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 12 GB Video Card  ($549.99 @ Newegg)
Case: Deepcool CC560 ATX Mid Tower Case  ($59.99 @ Adorama)
Total: $1603.81
Generated by PCPartPicker 2023-11-19 21:13 EST-0500
so heres the build and i would like suggestions on how i could improve it or if some parts arent compatible i would also like to know how easy the case is to work in. (this is the absolute highest i will go budgetwise). im also wondering how it stacks up for gaming and streaming pourposes.
Edited by Byamps
forgot to specify what it would be used for
Small cost shifting.
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard  ($159.99 @ Amazon)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($89.99 @ Amazon)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($89.99 @ Best Buy)
Power Supply: Thermaltake Toughpower GF A3 - TT Premium Edition 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $1564.82
Generated by PCPartPicker 2023-11-19 21:44 EST-0500
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
so i had a build i was liking but i had to change a couple things because i couldn't find some parts on amazon so i would like it re rated to make sure all the parts are compatible and its not going to run bad for the uses i want it for. (gaming and streaming/video editing)
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($358.98 @ Newegg)
Motherboard: Asus ROG STRIX B650-A GAMING WIFI ATX AM5 Motherboard  ($199.99 @ Newegg)
Storage: Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($98.99 @ B&H)
Video Card: Gigabyte EAGLE GeForce RTX 4060 Ti 8 GB Video Card  ($399.99 @ Amazon)
Operating System: Microsoft Windows 11 Home OEM - DVD 64-bit  ($104.99 @ Newegg)
Total: $1471.80
Generated by PCPartPicker 2023-11-24 20:58 EST-0500
Total: $1471.80
If you pick better value parts, you can easily have 4070 or 7800xt instead of considerably slower 4060ti.
Motherboard: ASRock B650M Pro RS WiFi Micro ATX AM5 Motherboard  ($124.99 @ Newegg)
Storage: Lexar NM790 w/Heatsink 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($94.95 @ Amazon)
Video Card: MSI GAMING X SLIM GeForce RTX 4070 12 GB Video Card  ($544.99 @ Newegg)
Case: Phanteks Eclipse G300A (3 Fan) ATX Mid Tower Case  ($54.99 @ Newegg)
Total: $1497.77
Generated by PCPartPicker 2023-11-25 01:25 EST-0500
Lets make it a bit more complicated with 7600 and 4070ti as an option too if you have a 1440p monitor as then cpu will have less influence than having a 20% faster gpu as you are gpu bottlenecked even with the 7600.
Video Card: MSI VENTUS 3X E OC GeForce RTX 4070 Ti 12 GB Video Card  ($714.99 @ Newegg)
Total: $1507.79
Generated by PCPartPicker 2023-11-25 01:33 EST-0500
hopefully this is the last iteration of the pc and would like it rated (again)
Storage: Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($98.99 @ Adorama)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 12 GB Video Card  ($549.99 @ B&H)
Case: MSI MPG GUNGNIR 110R ATX Mid Tower Case  ($79.98 @ Amazon)
Total: $1621.80
Generated by PCPartPicker 2023-11-25 13:56 EST-0500
