Hi guys,
Im looking to buy myself a new monitor, this will preferably be 24 inch 1080p 60hz is fine. However the difficulty is i want this to be controllable with a remote control. I really want to control the input and i will probably be running these in duel display so if the control will control two of the monitor that'd be perfect. I dont want to buy a smaller tv just because of input lag etc. I will be gaming on this monitor slighty. Budget is fairly small but there is no set price.
Thanks for your help.
Rich
"Be excellent to one another" Bill and Ted
"How many people have died waiting for their Savour" Nick Arthur of Molotov Solution
https://linustechtips.com/topic/154142-remote/
ehm. What do you want to control?! O.o
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/154142-remote/#findComment-2055757
The input only really. Power would be nice, but not necessary :P
Oh i also forgot to mention, i'll change the main article thing as well, but i will probably be running 2 of these monitors so if theres even the smallest chance that they can link together, it would be perfect.. Thanks a lot again!
https://linustechtips.com/topic/154142-remote/#findComment-2055790
Why dont you just push two buttons on the monitor and you have that covered?
Cause you wont find a decent remote controlled monitor.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/154142-remote/#findComment-2055813
Just my use case really mate, i will use them when i am at my desk however when i am in bed there are times i do not want to get out of bed to change the source. I know this is an extremely lazy persons problem...
https://linustechtips.com/topic/154142-remote/#findComment-2055843
