mobo asus z690 hero bios 2802
i9 14900k sp98 p106 e84 mc80
cooler nh-d15
i see a lot of people with sp like mine overclock the cpu to 5.7 with 1.16-1.8v
mine need 1.21-1.22 llc6 and bios prediction show 1.19 and still the cpu not stable
does i have bad cpu? does it motherbord problem? or mybe the cooler?
thanks for the help
https://linustechtips.com/topic/1541081-help-overclock-i9-14900k/
nh-d15 not good enough. i9 makes 360mm AIO's throttle. No only one tower cooler really is able to handle that heat.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
