Need clarification on audio frequency
Go to solution Solved by Heats with Nvidia,
On 11/11/2023 at 6:19 PM, Kamranbites said:
In Parallel: A capacitor in parallel with a subwoofer generally allows low frequencies to pass and attenuates higher frequencies.
In Series: Placing a capacitor in series with a subwoofer would act as a high-pass filter, allowing higher frequencies to pass while blocking lower frequencies.
The only caveat is, please don`t connect a capacitor directly in parallel to a subwoofer without anything between it and the amplifier, since at higher frequencies, it will be a short circuit for the amplifier, which might damage it.
https://linustechtips.com/topic/1540347-need-clarification-on-audio-frequency/
