How to Replace a System and Primary Partition.
Solved by Daymin,
Solution:
- Copied the partition sector by sector with DiskGenius. (You need to create a new partition with the exact same sector amount as the one to be copied)
- Ran "bcdboot C:\Windows /s C:" in cmd/powershell
- Power down PC
- Remove OLD SSD
- Reboot
- Done
Featured Topics
ImMiles ·
Posted in New Builds and Planning1 -
D-pacman ·
3
generic000 ·
Posted in Graphics Cards6 -
Cringe_Master245 ·
Posted in CPUs, Motherboards, and Memory1 -
Rideonbrother ·
3
5
play_circle_filled
Latest From ShortCircuit:
I'm a Huge Sucker for a Cool Gimmick - Epomaker DynaTab 75X & DynaTab 75
play_circle_filled
Latest From Mac Address:
The Apple Vision Pro Leaves a Mark (but not the right kind)
