Asus prime 7608-p wifi mother board
Intel i7-12700k processor
Deep cool ak620 cooler
Gigabyte ultra durable golf 750w 80 plus hold PSU
GeForce tx4060
This is my first build and I'm at the point to bench test before installing to the case. I'm not getting any video and possibly not enough power. Cpu thermal paste and pins are ok. Everything is seated correctly. HDMI goes to GPU. Even tried booting without GPU using the on board graphics with nothing. When turned on the fans and RGB kick on. However when PSU is on there are no lights on the motherboard. Only indication it's on is that RGB and fans are running. Tried moving ram stick and removing one to no help. Redid the thermal paste and checked the pins. HDMI cable and monitor worked perfect yesterday.
https://linustechtips.com/topic/1539643-help-with-new-build/
a rtx 4060 damn your better of getting a 3060 its a big waste of money. what does the debug light on the motherboard show? depending on the color it can tell you which part may be acting colors can vary from motherboard to motherboard. And what is a Asus prime 7608-p wifi mother board? there is no such thing may be a typo... try resetting the cmos of the mobo.
https://linustechtips.com/topic/1539643-help-with-new-build/#findComment-16196884
I needed the better one for what I do. Sorry it's Asus prime z690-p tried resetting CMOS already. My board doesn't have debug leds
https://linustechtips.com/topic/1539643-help-with-new-build/#findComment-16196906
13 minutes ago, Zombotomy said:
well everything look to be hooked up right, Basic stuff have you tried just running off of onboard graphics and 1 ram stick. Literally the basic needs to get it started. If it works from there just keep adding slowly til it stops working again and that should point to the issue.
Technology is like a good friend that does its best to piss you off at every turn. yet we love them anyway.
https://linustechtips.com/topic/1539643-help-with-new-build/#findComment-16196920
