I have this weird ram problem where when I put in a second stick it doesn’t matter wich slot the first one is in neither does it matter in wich slot the second on is I get a red light on my motherboard and it says something’s wrong with my ram.
motherboard is Msi b450f
cpu Ryzen 7 3700x
gpu amd radeon rx 6750xt
please help me can’t find any solution
https://linustechtips.com/topic/1539101-weird-ram-problem/
MSi B450F? Do you mean ASUS B450-F?
Red LED = CPU Error
Yellow LED = DRAM Error
Is the error tied to THAT one stick of RAM?
If you put in the second stick, and it comes up with an error, then it is VERY likely the memory stick is faulty.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1539101-weird-ram-problem/#findComment-16192855
Red LED = CPU Error
Ah yeah I meant ASUS somehow switched it up, anyway it’s not tied to a particular stick it’s just when I add a second one
https://linustechtips.com/topic/1539101-weird-ram-problem/#findComment-16195100
