2 minutes ago, DeanDanyels said:
I have an Ryzen 3 2200g,will it be compatible with an ASRock A520M-HDV?
check here https://www.asrock.com/support/cpu.asp?s=AM4
https://linustechtips.com/topic/1538711-will-it-be-compatible/#findComment-16189714
It's definitely not compatible. The mb only supports 3rd to 5th gen, and the cpu is a 2nd gen. Think of getting a 3rd or 4th gen ryzen cpu, their prices are affordable. The ryzen 5 5600 is the best value for money, or a lower gen g series if you'r still saving for a gpu.
https://linustechtips.com/topic/1538711-will-it-be-compatible/#findComment-16189730
No it's not compatible
According to the table of compatibility @PDifolco linked it isn't compatible as an 'a520' board doesn't show up image.thumb.png.b85383cfe8f69cd0f68d683eda8b911c.png
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1538711-will-it-be-compatible/#findComment-16189743
Haha  DDTS has just solved the issue 🙂
He's calling the PC "Depresserion" 😄, and a 3060 won't fit... dHell may put  custom LP 3060 in these systems 😞
https://linustechtips.com/topic/1538711-will-it-be-compatible/#findComment-16190074
