VGA PCI-E Damage
Solved by Eigenvektor,
The pins and the card look fairly corroded. You could try cleaning the pins with alcohol as a first step. You could potentially fix them by adding additional material (if it no longer works as-is after cleaning), if you have the skill. Otherwise, you could hand it to a repair shop, but the question is if the repair would cost more than a new card.
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
Posted in New Builds and Planning9
