Planning upgrade advice
Go to solution Solved by Why_Me,
41 minutes ago, JayTM said:
Budget (including currency): $500-$1,000
Country: USA
Games, programs or workloads that it will be used for:
I currently have a prebuilt Cyberpower pc that I'm looking to upgrade my components every so often. I've been struggling to decide where to start. I was thinking of upgrading to a 4070 or 4080, i7-13700k or i9-14900k, better case, or upgrading the motherboard & ram together to a Z790 & DDR5. Overtime I'd like to do all the upgrades but just not sure where to start. Below is a list of my current setup. Thanks in advance for any input.
CPU- I7-12700KF
CPU Cooler- 240mm radiator
Motherboard- MSI Pro Z690-A
RAM- 4x8 G.Skill Trident Z DDR4-3200 CL16
GPU- Gigabyte 3070 Eagle OC
Case- Cyberpower Amethyst II
Storage- 2TB Samsung 990 Pro & 2 1TB Samsung 990 Pro
Power Supply- EVGA 800 GD
Monitor- Gigabyte M27Q 1440P
Upgrade the gpu and call it a day.
Country: USA
CPU- I7-12700KF
https://linustechtips.com/topic/1538293-planning-upgrade-advice/
Country: USA
CPU- I7-12700KF
What's your budget for the upgrade?
If it's $1000 try and get a new case like the lian li lancool 216 and a 4070
if it's $2000 then try this build
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($369.00 @ Amazon)
CPU Cooler: ARCTIC Liquid Freezer II 360 A-RGB 48.8 CFM Liquid CPU Cooler  ($146.13 @ Amazon)
Motherboard: Gigabyte B650 AORUS ELITE AX ATX AM5 Motherboard  ($219.99 @ Amazon)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  ($93.99 @ Newegg)
Video Card: ASRock Phantom Gaming OC Radeon RX 7900 XTX 24 GB Video Card  ($949.99 @ Newegg)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  ($104.99 @ Adorama)
Power Supply: Thermaltake Toughpower GF3 TT Premium 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($154.99 @ Amazon)
Total: $2039.08
Generated by PCPartPicker 2023-10-29 16:36 EDT-0400
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
Total: $2039.08
My budget for now would be $500-$1,000 and then the same for future upgrades in a few months. The case & 4070 would be a good place to start. I'll definitely check out that case.
Actually, for 1000 bucks I’d get a 7900 xt or 7900 xtx and the lian li LANCOOL 216
Total: £1040.95
Country: USA
CPU- I7-12700KF
my question would be if you even need to upgrade the PC, or are you just upgrading for the sake of upgrading?
perhaps GPU could be a first thing, depends what games you play or what you do on it,
because a better thing could be to wait if intel or AMD changes socket again, to then jump on that if it's any good along with a Case upgrade because if you're upgrading CPU and MB you might aswell upgrade the Case,
or in short, just get a better GPU at least one that your PSU can handle
current PC:
PC configs I used before:
I second this, i7 1200kf is more than enough. I was getting ~130 fps with a 5820k from almost a decade ago. I would get a 4090 and enjoy it for quite a while!
Shipping sucks
