Hi guys,
I have an old AsRock H97 board which for whatever reason won't hold onto a Wifi connection for longer than a few minutes.
It will connect and work for a minute or 2, drop then reconnect and do this perpetually.
See Windows event viewer log that looks like is pointing to a possible problem.
Strange thing is, its definitely the only PC on my network with the same name and I don't have anything running with static IPs so everything is DHCP.
Wired connection works perfectly on the same PC.
Fresh install of Win 10 / 11 doesn't help.
Might boot Ubuntu to see if that works but any ideas in the meantime?
Cheers
C
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1538075-pc-wi-fi-issues/
Make and model of wireless adapter?
Are you trying to use WiFi while connected to ethernet? What if you physically disconnect the ethernet cable and try connecting via WiFi?
https://linustechtips.com/topic/1538075-pc-wi-fi-issues/#findComment-16185064
Its a Realtek 8821AE Wireless LAN 802.11ac PCI-E NIC
Nope. I don't have it connected with CAT6 but do have a cable and switch nearby to test it with.
Booted the offending system a couple of mins ago to get the wifi nic model without a cable and was connected when logging into Windows but by the time I had opened device manager, it had dropped connection.
3 hours ago, emosun said:
Use a different wifi adapter vs the stock one built into the board
If its at fault then I'll need to get a USB one as the board is ITX and the PCIe slot is occupied with my GPU.
Just strange the the event log is reporting another PC on the network with the same name but there isn't.
Got quite a few PCs at home but all with different names and not all on at the same time.
https://linustechtips.com/topic/1538075-pc-wi-fi-issues/#findComment-16185212
im using one right now , works fine. i'd advise getting a decent quality one as the super cheap ones might as well be broken from the factory
https://linustechtips.com/topic/1538075-pc-wi-fi-issues/#findComment-16185230
Not necessarily, you may be able to replace the Realtek with an Intel AX210 if its in an M.2 slot.  Unfortunately this is often hidden behind the IO shield so a little tricky to get at.
But if you have a cable and switch nearby, can you not just use that permanently?  Wired is always more reliable.
https://linustechtips.com/topic/1538075-pc-wi-fi-issues/#findComment-16185507
Yeh, could do. Its really just a troubleshooting thing. Got no idea why the event viewer is reporting another system on the network as having the same name.
Actually, easier than that. The M.2 slot is smack bang in the middle of the board so very easy to get to.
I'm sure I've got a spare usb wifi adapter kicking around my box of goodies somewhere so will give that a bash first.
https://linustechtips.com/topic/1538075-pc-wi-fi-issues/#findComment-16185779
The fact that an ethernet connection doesn't give any problems suggests to me that your router shouldn't be ignored. Have you tried rebooting the router/AP to see if the problem fixes itself?
The connectors/contacts have to match. Also ensure the antenna cables are attached properly at both ends.
https://linustechtips.com/topic/1538075-pc-wi-fi-issues/#findComment-16185970
Yeh, that was the first thing I did.
Is it called an Arp Table? Kinda thought something had got stuck in something like that and causing a conflict.
I think I'm gonna test it with a crappy old USB one that I'm sure I've got kicking around somewhere and assuming it fixes the problem, I'll buy something faster. If the problem persists then its square one but no great loss as the PC is rarely used and is next to a CAT6 cable anyway.
https://linustechtips.com/topic/1538075-pc-wi-fi-issues/#findComment-16186070
Oh yeah I actually HAVE that board.  Drawback is its miniPCIe not M.2.
So you'd need a miniPCIe to M.2 adapter and new antennas to connect a newer card.  The mounting bracket probably wont fit then either, but honestly I ran mine for years as a NAS without it with a SATA card in that slot.
https://linustechtips.com/topic/1538075-pc-wi-fi-issues/#findComment-16186523
Doesn't the Intel AX210 come in a half-mini PCIe form factor?
M.2 2230, M.2 1216, unless some Chinese company made an unofficial version.  I've never seen anything past WiFi 5 in miniPCIe.
https://linustechtips.com/topic/1538075-pc-wi-fi-issues/#findComment-16186820
