You can't, this motherboard does not have onboard wifi. Only thing you can do is either plug in an ethernet cable or get a wifi adapter/card.
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
https://linustechtips.com/topic/1537541-please-help-me/#findComment-16180824
15 minutes ago, Dioxazine said:
b450a-m pro max
This bored dosn't have Wi-Fi. I recommend you buy yourself a PCIe Wi-Fi card. They can be had for about £20-30.
Something like this: https://uk.pcpartpicker.com/product/kz8j4D/tp-link-archer-t4e-pcie-x1-wi-fi-adapter-aa528899
I might be experienced, but I'm human and I do make mistakes. Trust but Verify! I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need. Expand this signature for common PC building advice, a short bio and a list of my components.
Common build advice:
1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticeably improve performance past 240mm and don't improve at all past 360mm. 9) RTFM.
Useful Websites:
https://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
Bio:
He/Him - I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 4 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). Aside from computers, I also dabble in modding/homebrew retro consoles, support Southampton FC, and enjoy Scuba Diving and Skiing.
Fun Facts
1) When I was 3 years old my favourite toy was a scientific calculator. 2) My father is a British Champion ploughman in the Vintage Hydraulic Class. 3) On Speedrun.com, I'm the world record holder for the Dream Bobsleigh event on Mario & Sonic at the Olympic Winter Games 2010.
My Favourite Games: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii, Balatro
My Computers: Primary: My main gaming rig - https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C Second: Hosts Discord bots as well as a Minecraft and Ark server, and also serves as a reinforcement learning sand box - https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P NAS: TrueNAS Scale NAS hosting SMB shares, DDNS updater, pi-hole, and a Jellyfin server - https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C Foldatron: My folding@home and BOINC rig (partially donated to me by Folding Team Leader GOTSpectrum) - Mobile: Mini-ITX gaming rig for when I'm away from home -
https://linustechtips.com/topic/1537541-please-help-me/#findComment-16180831
42 minutes ago, Dioxazine said:
So i just finished my build i turned it to an i dont have an antenna to use but my motherboard has (its a b450a-m pro max) how do i turn on the wifi? Wirelessly
As peoples above stated, the board doesn't come with Wifi capability.
Either use a PCIE Wifi Card, or Wifi USB Dongle.
IMHO, unless you need some sort of niche feature / setup that only comes with PCIE wifi card. Wifi USB dongle is cheap, simple and good enough.
Refresh before you reply
https://linustechtips.com/topic/1537541-please-help-me/#findComment-16180848
It says it has intergated lan reltek 8111h
https://linustechtips.com/topic/1537541-please-help-me/#findComment-16180861
Yea that's ethernet.
here's an example, a snip of specification page from MSI B550m Mortar Wifi :
Here's another snip from ASUS TUF B550m-PLUS Wifi :
https://linustechtips.com/topic/1537541-please-help-me/#findComment-16180871
17 minutes ago, Dioxazine said:
Yes but i cannot connect to the router
You do NOT have a wireless card on the board
You need to buy a PCIe or USB WiFi card
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1537541-please-help-me/#findComment-16181438
No, not that, nobody should be buying WiFi 5 adapters now.
But if they have GPU they literally can't fit a PCIe card in that motherboard anyway.
That motherboard was a bad choice if you need WiFi as you have no space to put a WiFi card if you are using a GPU.  You're going to have to put up with some crappy USB adapter, or use a wire to your router.
https://linustechtips.com/topic/1537541-please-help-me/#findComment-16181439
I was under the impression WiFi 5 was cheaper and fast enough not to be a bottleneck for the average household internet connection (or atleast it is in the UK). Has this changed?
Hadn't noticed that, this is going to be a problem.
Useful Websites:
Bio:
Fun Facts
https://linustechtips.com/topic/1537541-please-help-me/#findComment-16181478
That is the ethernet controller, the board dosn't have WiFi.
See the product page: https://www.msi.com/Motherboard/B450M-A-PRO-MAX/Overview
As it dosn't have the slots to add a wifi card, I suggest returning the motherboard.
Useful Websites:
Bio:
Fun Facts
https://linustechtips.com/topic/1537541-please-help-me/#findComment-16181484
Its not just about speed, if your router has WiFi 6 then its likely to also improve latency.
Also WiFi 6 cards are dirt cheap, you don't need to go for branded products just something based on Intel AX200 or AX210 with a really basic PCIe to M.2 adapter.  You're really just paying for the look on branded models, most don't even need those heatsinks as they're just identical to the laptop cards underneath.
https://linustechtips.com/topic/1537541-please-help-me/#findComment-16181497
