image.thumb.jpg.558c4cfc9187b0d7d567399cebde748f.jpgSo could anyone tell me what this big white thing is it came with the case it has all of the fans wires into it and i plugged a sata power to it
(still waiting for my cpu to get here)
and i dont know if its correct because there is nothing else to fit there and i think its for power only
This is from the same header i plugged into that fan port thing but none of the other sata cables has one of these small ones and i dont know what it is used for maby for the fans ?
https://linustechtips.com/topic/1537334-help-please/
First picture shows multiple MOLEX connectors (which are used for powering ancient components and auxiliary devices). Second picture shows a floppy disk power connector, which has been obsolete for the last 25 years as of today.
https://linustechtips.com/topic/1537334-help-please/#findComment-16179195
I always hated those pass through MOLEX connectors
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1537334-help-please/#findComment-16179212
Ok so i plugged a sata power in the molex and the second i will guess its usless so yea
first is the sata power connector thing to be in the Molex thing? Cuz i dont have anything else to plug in that to give it power
https://linustechtips.com/topic/1537334-help-please/#findComment-16179216
What kind of power supply is that? It seems ancient and could be unsafe to use, at least with regards to your components. The only modern day use for Molex would be to power fans if there aren't enough fan headers. And you can usually just power two fans from one header with a splitter, which is a better and neater choice.
Also, it looks to me as if the black plug plugged into the series of white Molex connectors is also a Molex, not SATA. I may be wrong though, hard to tell from the picture.
https://linustechtips.com/topic/1537334-help-please/#findComment-16179270
Can you fans be powered using anything else than the white molex connector? Something like a 3 pins (DC) or a 4 pins (pwm) connector that would connect directly to a MB header?
Some fans offer multiple option for power (to make sure they're compatible with older systems). Molex is the worse of all options. You won't need to use the molex connector if you can use DC or PWM instead.
If your fans only have molex for power, this means they are pretty ancient, and thus maybe noisy as well. You might consider replacing them with newer ones (that use DC or PWM) if you have the spare cash.
https://linustechtips.com/topic/1537334-help-please/#findComment-16179615
Ye i will replace them cuz they only got the molex …
https://linustechtips.com/topic/1537334-help-please/#findComment-16179688
