Advice on first build
Go to solution Solved by RONOTHAN##,
27 minutes ago, TMFalcon90 said:
I had read about the BIOS update needed, still working that out, to be sure, it has to be a 12th gen to update the BIOS?
Yeah, it's got to be a 12th gen chip. If you have a friend with one, borrow it and update the BIOS, but if you don't it's not a massive performance difference from 12th gen to 13th gen and wouldn't really warrant trying that hard to get the BIOS updated.
32 minutes ago, TMFalcon90 said:
I don't have the peripherals, but the monitors aren't included in the $1000, that is for the rig itself.
If that's the case, you can step up to a 12700KF instead with a PSU and cooler upgrade and have a bit of money left over.
https://au.pcpartpicker.com/list/gJPFZJ
Hi team, I decided to build my first PC from scratch after wanting to modify an old PC I was given but never got around to it.
(Old PC is not being used in build)
I have a few items already
Case: Lian Li Lancool 215 atx
Mobo: Asus TUF GAMING Z690-PLUS WIFI D4 ATX LGA1700
GPU: Gigabyte WINDFORCE GeForce RTX 2070 8 GB
I wouldn't mind putting in an i5-13600k into the system even though it might be overkill.
1. Budget & Location
Currency is $AUD, budget is looking around ideally no more than $1000 on the rest of the system
2. Aim
Good performance gaming in 1080 and 1440p, upgrade room for future, maybe even leading to 4k. Spreading a range of game genre(MMOS, RPG, FPS, RACING as examples).
3. Monitors
1-2 monitors, decent 27-32 inch, not sure about resolution. Most likely 1 monitor to start with.
4. Peripherals
Razer Naga X/trinity
Razer keyboard
 P9ssibly unnecessary but maybe  Razer tartarus.
5. Why are you upgrading?
First personal build by myself.
Any help is greatly appreciated.
https://linustechtips.com/topic/1537210-advice-on-first-build/
Main problem with this is the motherboard's BIOS. ASUS for reasons unknown to me (probably upselling their higher end boards) only put BIOS Flashback on their ROG and ProArt boards, so unless you can borrow a 12th gen CPU to do a BIOS update, the system won't work with a 13th or 14th gen CPU and you'd be stuck going for a 12600K or 12700K.
3. Monitors
4. Peripherals
Razer keyboard
Just to confirm, is are these necessary to purchase within that ~$1000 budget or do you already have them. The way I read it you need the monitors but not the peripherals, but I could very well be wrong.
https://au.pcpartpicker.com/list/484MCd
https://linustechtips.com/topic/1537210-advice-on-first-build/#findComment-16178218
https://linustechtips.com/topic/1537210-advice-on-first-build/#findComment-16178224
https://linustechtips.com/topic/1537210-advice-on-first-build/#findComment-16178237
That actually gives me a bit more to think about, bit of saving is always nice. Much appreciated.
https://linustechtips.com/topic/1537210-advice-on-first-build/#findComment-16178249
