Full specs please
But from the little you gave that superpower psu is basically a firehazard and most likely just died when you plugged in the r9 270.
It's basically made out of nothing and NOT a 500w psu not even close.
This is why having a quality psu is important and they aren't even that expensive.
https://linustechtips.com/topic/1536862-i-need-help/#findComment-16175778
2 hours ago, jaslion said:
Full specs please
CPU AMD Ryzen 3 2200g,16gb ram from Kingston,512 GB m.2.So you're suggesting to buy a new PSU?And also,maybe it's not the PSU,because the pc works,but no display output and power cycling.Would a HPC ATX 550
Watts work?
https://linustechtips.com/topic/1536862-i-need-help/#findComment-16175946
Watts work?
Well yeah it hard crashed that psu is probably fucked and since it's cycling something else might be dead.
No that is just as bad and has been for the 12 years it's existed. You aren't find a psu for under 25$ that won't kill your pc. Unless you go used and there you have to be very carefull
https://cultists.network/140/psu-tier-list/
Legit DO NOT go lower than c tier that is where pc damage starts.
I hope your system isn't fried but there is a good chance. No real way to really test without replacing the biggest culprit the psu.
And stop using it for now it's only causing more harm.
Whats the budget for a replacement?
https://linustechtips.com/topic/1536862-i-need-help/#findComment-16175966
Up to 50 bucks,cuz in my country,that's a high price for PSUs,hell,even that HPC is 30 bucks
https://linustechtips.com/topic/1536862-i-need-help/#findComment-16175979
