Budget (including currency): $800 AUD
Country: Australia
Games, programs or workloads that it will be used for: Minecraft Forza Horison 5 CSGO valorant
All games 1920x1080 144hz Fine with lower if i have to.
Should be able to record/stream Minecraft specifically.
Minecraft something like this -
https://linustechtips.com/topic/1536812-pc-build-help/
Country: Australia
Didn't we already find a solution in the other thread
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1536812-pc-build-help/#findComment-16175337
5 minutes ago, iVirtuall said:
Wifi
Go for this then
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($209.00 @ Centre Com)
Motherboard: MSI B550M PRO-VDH WIFI Micro ATX AM4 Motherboard  ($169.00 @ Centre Com)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($55.00 @ MSY Technology)
Storage: TEAMGROUP MP33 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($60.00 @ MSY Technology)
Case: Antec NX200M MicroATX Mid Tower Case  ($51.75 @ Amazon Australia)
Power Supply: Gigabyte P-B 650 W 80+ Bronze Certified ATX Power Supply  ($75.00 @ MSY Technology)
Custom: Used RX 6600 ($230.00)
Total: $849.75
Generated by PCPartPicker 2023-10-20 18:13 AEDT+1100
Total: £1040.95
https://linustechtips.com/topic/1536812-pc-build-help/#findComment-16175348
9 minutes ago, filpo said:
Go for this then
Total: $849.75
wouldn't a 5600g be better?
https://linustechtips.com/topic/1536812-pc-build-help/#findComment-16175353
Nope. Slower PCIE.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1536812-pc-build-help/#findComment-16175390
32 minutes ago, venomtail said:
Nope. Slower PCIE.
hell a 3600 would be better value than the 5600g
Also it has less cache than the 5600 which means worse gaming performance (not all the time but cache does play a big part in gaming performance, just look at the 5800X3D and 7800X3D)
5600:
5600g:
Total: £1040.95
https://linustechtips.com/topic/1536812-pc-build-help/#findComment-16175416
