Hi,
I have a 10 year old prebuilt PC that I only really play league on. I am looking to build a computer so I can start getting into PC gaming. I am new to this, but I have been doing a lot of research recently to try to maximize the computer's performance for my budget. I am hoping there will be good discounts for black friday. Even though this is currently below my budget, I would rather save money than upgrade this build significantly. I would appreciate any helpful tips or advice, whether they are about picking different parts or if there is anything I should keep in mind when building it.
Budget (including currency): $1500
Country: USA
Games, programs or workloads that it will be used for: Baldur's Gate 3, Last of Us, Overwatch, etc.
https://pcpartpicker.com/list/wsMh34
https://linustechtips.com/topic/1536479-first-build/
what are the specific specs of this prebuilt? You could probably keep the case and that would save enough to squeeze in a 7900 xt
Country: USA
1440p?
try this
PCPartPicker Part List
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor  ($322.72 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($34.90 @ Amazon)
Motherboard: Gigabyte B550 UD AC ATX AM4 Motherboard  ($99.99 @ Newegg)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($29.97 @ Amazon)
Storage: TEAMGROUP MP33 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($70.97 @ Amazon)
Video Card: XFX Speedster MERC 310 Black Edition Radeon RX 7900 XT 20 GB Video Card  ($789.99 @ Amazon)
Case: Phanteks Eclipse G300A (1 Fan) ATX Mid Tower Case  ($34.99 @ Newegg)
Power Supply: Cooler Master MWE Gold 850 - V2 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($95.99 @ Adorama)
Case Fan: ARCTIC P12 PST 56.3 CFM 120 mm Fans 5-Pack  ($29.99 @ Amazon)
Total: $1509.51
Generated by PCPartPicker 2023-10-18 04:36 EDT-0400
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1536479-first-build/#findComment-16172954
I'd go with something like this. I think faster CPU is a better option here than the older 5800X3D cause in certain games the CPU difference can be up to 30fps yet usually the fps difference between 7800XT and 7900XT averages around 10-20fps. Hard to say, especially which will age faster or need to work harder, in the future CPU or GPU:
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($369.56 @ Amazon)
CPU Cooler: Deepcool AK400 ZERO DARK 66.47 CFM CPU Cooler  ($39.99 @ Amazon)
Motherboard: ASRock B650 LiveMixer ATX AM5 Motherboard  ($179.99 @ Newegg)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  ($93.99 @ Newegg)
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($44.99 @ Amazon)
Video Card: Sapphire NITRO+ Radeon RX 7800 XT 16 GB Video Card  ($559.99 @ Newegg)
Case: Fractal Design Pop Air ATX Mid Tower Case  ($89.99 @ B&H)
Power Supply: Corsair CX750M (2021) 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($79.98 @ Amazon)
Total: $1458.48
Generated by PCPartPicker 2023-10-18 05:33 EDT-0400
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1536479-first-build/#findComment-16172997
Although I appreciate the suggestions, you guys both removed the monitor haha. The monitor is a necessary purchase as well and must be factored into the budget.
In response to @filpo the prebuilt case does not have enough airflow to support a modern gaming PC. I'm not sure I understand the point of upgrading the cpu to the 5800x3d. Upgrading the graphics card to the 7900 xt is a tempting thought, but I think the 7800 xt is more than enough for my gaming needs.
In response to @venomtail I don't see the benefit of upgrading to ddr5. The RAM you suggest has more latency and the whole build is made much more expensive because of ddr5. If I needed a better cpu, couldn't I get the 5900x?
Thanks
https://linustechtips.com/topic/1536479-first-build/#findComment-16173356
Thanks
Aight my bad, I saw the monitor, noted not to forget about it and when I started comparing the 3D chips completely forgot about them.
If you're considering gaming and AMD CPU's, only consider the 3D ones. They have massive caches that games absolutely love. Intel doesn't by comparison and sometimes their flagship i9 models even get beaten by large margins whilst the 3D chips often use half the power and run way cooler. For gaming they're really the only consideration.
AM5 is only DDR5, they left DDR4 behind them, you have no choice of RAM unlike intel's offering right now. 15th gen intel is also abandoning DDR4 and I've no idea yet how much 14th gen is impacted by DDR4. Yes DDR5 is a tad bit more expensive but for DDR4 it's the end of the road.
Likely you'll have to go with a 5800X3D to save on money, then a 7700XT with your 1440p monitor. Maybe manage to squeeze in a 7800XT with barebones parts elsewhere including monitor.
>>>I can make list later.
https://linustechtips.com/topic/1536479-first-build/#findComment-16173380
Thanks
try this edited version of @venomtail's build
Motherboard: Gigabyte B650 AORUS ELITE AX ATX AM5 Motherboard  ($219.99 @ Amazon)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  ($499.99 @ B&H)
Power Supply: Thermaltake Toughpower GF A3 - TT Premium Edition 1050 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.99 @ Newegg)
Total: $1494.37
Generated by PCPartPicker 2023-10-18 12:18 EDT-0400
Total: £1040.95
https://linustechtips.com/topic/1536479-first-build/#findComment-16173436
Thanks
I don't think I can squeeze any more out of a configuration like this, in terms of you having quality parts that won't slow each other down, perform well in 2023 and be within budget.
CPU cooling seems acceptable? Case should have included fans to ensure frech airflow.
The only other things you could look at reducing is noname storage, RAM and a bronze non modular PSU:
CPU Cooler: Thermalright Assassin X Refined SE PLUS 66.17 CFM CPU Cooler  ($19.50 @ Amazon)
Motherboard: ASRock B650M Pro RS Micro ATX AM5 Motherboard  ($119.99 @ Newegg)
Memory: OLOy Blade 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory  ($83.99 @ Newegg)
Video Card: ASRock Challenger OC Radeon RX 7800 XT 16 GB Video Card  ($499.99 @ Newegg)
Case: Deepcool MATREXX 40 3FS MicroATX Mini Tower Case  ($49.99 @ Newegg)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Newegg)
Monitor: Acer Nitro XV1 XV271U 27.0" 2560 x 1440 180 Hz Monitor  ($209.99 @ Amazon)
Total: $1497.99
Generated by PCPartPicker 2023-10-18 16:27 EDT-0400
https://linustechtips.com/topic/1536479-first-build/#findComment-16173695
Ok. That build looks pretty good to me @venomtail You make it sound like it was a challenge to get a good build in the budget. What would you change if the budget were $1800? $2000? Would the differences be significant to warrant increasing the budget?
https://linustechtips.com/topic/1536479-first-build/#findComment-16173924
Budget would only really need a small bump. Bigger cooler, motherboard, case, GPU and monitor. $150 extra for a computer I'd be 99% satisfied with, the 1% not knowing what your tastes are. Gone with a funky unique orange look. Not that they're required but slightly more name brands and just quieter whilst running:
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($369.38 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($37.90 @ Amazon)
Motherboard: ASRock B650 LiveMixer ATX AM5 Motherboard  ($169.99 @ Newegg)
Video Card: PowerColor Hellhound OC Radeon RX 7800 XT 16 GB Video Card  ($519.99 @ Amazon)
Monitor: MSI G272QPF 27.0" 2560 x 1440 170 Hz Monitor  ($239.99 @ Amazon)
Total: $1656.21
Generated by PCPartPicker 2023-10-19 03:19 EDT-0400
https://linustechtips.com/topic/1536479-first-build/#findComment-16174123
Nice. The orange look is a little funky but I think quieter is better for sure. I would like 2 TB storage. I am curious what are your thoughts on the different gpu video cards. If they are all 7800xt, what is the difference between the different types? Why are some more expensive?
https://linustechtips.com/topic/1536479-first-build/#findComment-16174462
