Help with first ever PC build
42 minutes ago, NicksGameDevelopers said:'ve selected from CCL(https://www.cclonline.com)
does it have to be only CCL?
42 minutes ago, NicksGameDevelopers said:Given my components, how significant is the bottleneck likely to be with the NVIDIA GeForce GT 710, especially in gaming scenarios?
do NOT get the gt 710. Even a gt 1030 won't be that much better
43 minutes ago, NicksGameDevelopers said:If I were to upgrade my GPU in the future, what options would you recommend to balance out the system's performance?
Don't think about that now, the market will change and so will your budget for a new dgpu
43 minutes ago, NicksGameDevelopers said:What are your thoughts on the other components I've chosen, such as the Ryzen 5 5600G, motherboard, and power supply?
The psu is OK but it could be improved. the mobo is good, but not in a budget build. The cpu is good too but what I'd do is get a used 3600 and then get a used dgpu like the rx 580
46 minutes ago, NicksGameDevelopers said:I am planning to spend about £400 GBP
is this your budget for the rest of the components to be bought or all the components prices combined (including the ones bought already)
47 minutes ago, NicksGameDevelopers said:NVIDIA GeForce GT 710 2GB (Graphics Card) (already purchased)
return this
- Crucial BX500 480GB SSD (already purchased)
- 2TB HDD (already purchased)
and these two
42 minutes ago, NicksGameDevelopers said:Are there any specific adjustments I can make to mitigate this bottleneck without investing in a high-end GPU right away?
I think it looks good to me, though I could make a few changes to the build
You'll get a much better experience
Try this if you wanna go all new
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor (£109.99 @ Amazon UK)
Motherboard: Gigabyte B550M DS3H Micro ATX AM4 Motherboard (£89.00 @ Computer Orbit)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (£29.99 @ Amazon UK)
Storage: Crucial P3 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (£79.97 @ Box Limited)
Case: Deepcool MATREXX 30 MicroATX Mini Tower Case (£29.99 @ Scan.co.uk)
Power Supply: MSI MAG A550BN 550 W 80+ Bronze Certified ATX Power Supply (£45.94 @ Box Limited)
Case Fan: ARCTIC P12 PST 56.3 CFM 120 mm Fans 5-Pack (£27.89 @ Amazon UK)
Total: £412.77
Generated by PCPartPicker 2023-10-17 22:20 BST+0100
And this if you wanna go all used
Power Supply: Gigabyte P-B 650 W 80+ Bronze Certified ATX Power Supply (£51.99 @ CCL Computers)
Custom: Used B550M DS3H (£65.00)
Custom: Used R5 3600 (£65.00)
Custom: Used Crucial P3 2TB (£60.00)
Custom: Used RX 580 (£72.00)
Total: £401.86
Generated by PCPartPicker 2023-10-17 22:30 BST+0100
