Booting NVMe drive from older/unsupported motherboards with clover - A simple guide
As the title suggest, this guide will make you able to boot directly an NVMe drive with older motherboard that does not support booting trough NVMe protocol natively. Some preparation and checklist is including (and not limited to):
  • Other PC that will be used to prepare the Bootable clover USB drive - Or you can use your target system that already have OS installed in other drive (SATA SSD/HDD)
  • Motherboard with at least 1 free PCIe slot - having physical PCIe x4 or larger that unoccupied will help, but you can also put the NVMe drive in PCIe x1 slot with some speed penalty
  • Motherboard with USB boot capabilities - Please beware, sometimes SD/MicroSD card reader built inside your laptop may doesn't support boot mode inside the BIOS
  • An PCIe NVMe drive - Make sure it's not a M.2 SATA or M.2 PCIe AHCI SSD!
  • A M.2 M Key to PCIe x4 adapter - for motherboard that only have PCIe x1 slot free, please bought applicable adapter or you can butcher either your adapter or motherboard PCIe slot (NOT RECOMMENDED)
  • An unused USB drive or SD Card/MicroSD with the USB adapter - 2GB or more in capacity with good transfer speed recommended, but you can getaway with smaller drive (at least 128MB or more)
  • Internet connection - For downloading the clover files
Tested system:
  • Dell Inspiron 3647 / Vostro 3900 (i3-4160) + Samsung PM891a 512GB NVMe SSD - Windows 10 - UEFI (Used in this guide)
  • Lenovo ThinkPad T430 (i7-3610QM) + Western Digital SN530 256GB SSD - Manjaro 20 KDE Plasma - UEFI
  • Lenovo ThinkPad T400 (C2D P9700) + Western Digital SN530 256GB SSD - Manjaro 20 KDE Plasma - UEFI
  • Asus X453MA (Pentium N3540) + Kingspec NE 2242 128GB SSD - Windows 10 - UEFI
  • ASUS Z8NA-D6C (2x Xeon X5650) + Samsung 960 Evo 256GB - Windows 10 - UEFI
  • Asrock P4i945GC (Pentium 4 550 HT) + Kingspec NE 2242 128GB SSD - Debian 10 XFCE Minimal - Legacy
Guide (Windows - Type all command without the quotation mark):
  1. Make sure your NVMe drive is recognized in other system, you can do this by booting an OS from officially supported media, and see if partition in the drive is either detected or mounted, or you can launch your OS specific disk drive manager like Windows Disk Management (windows) or lsblk (Linux) and see if the NVMe drive is detected.
  2. Download the clover files here - Choose the latest release, in the case of writing this article is CloverV2-5155.zip
  3. Prepare your SD/USB drive, make sure you backup your important data before formatting it. launch diskpart, either trough run or windows search or command prompt/Windows Terminal/Powershell, this will prompt windows admin warning, click OK to continue
  4. Now type "list disk", and you can identify which drive is the USB drive you mount by see the total capacity (in my case is disk 2)
  5. Type "select disk X" (X = your SD/USB disk number, eg. "select disk 2), and type "clean" to delete all partition (WARNING - YOUR DATA WILL BE DELETED)
  6. Now open windows Disk Management, and find your SD/USB disk that already been formatted, right click on formatted partition, and select "New simple volume" option
  7. For the size, type "512" (in MB; for USB/SD drive capacity more than 512MB), and click next, and select your desired drive letter path (or use default assigned by windows) and click next
  8. For filesystem, choose FAT32, with default allocation size, and volume label "clover" for ease of navigation later and click next and finish
  9. After your new partition is successfully mounted, extract the zipped clover folder, and go to inside of "CloverV2" folder, and copy the content to your USB drive
  10. now inside your USB Drive root folder, copy "NvmExpressDxe.efi" file, located in "/EFI/Clover/drivers/off" folder, to "/EFI/CLOVER/BIOS", "/EFI/CLOVER/UEFI", "/EFI/CLOVER/drivers32uefi", and /EFI/CLOVER/drivers32uefi" folder respectively.
  11. Now, back to your USB Drive root folder, go to "/EFI/CLOVER" folder and rename "config-sample.plist" to "config.plist".
  12. Edit the "config.plist" file with notepad or other plain text editor (Notepad++ is recommended)
  13. Find "<Key>Boot</Key>" line and scroll down a bit and you will find "<Key>Timeout</Key>" line, below that, default value is "<interger>5</interger>", this value represented how many second clover will automatically boot when user input is not detected, you can change it to your desired value, in my case, I put "10" for 10 seconds. Save and close the text editor.
  14. Now reboot your PC, and select boot drive to the USB/SD drive (either using boot menu shortcut or set it up manually via BIOS boot order). If you see the clover boot menu, congrats!
  15. Now shutdown your PC, plug your NVMe drive (if not already), and try to boot from it. If your NVMe drive doesn't have any OS installed, please install it like usual.
  16. Now, after installing either your NVMe drive or installing the OS inside it (or both), you can directly boot to the NVMe drive via the clover boot menu selector!
Photos for the guide:
Diskpart:
Windows Disk Management (in this case clover drive already prepared beforehand):
Clover root folder inside the USB/SD drive:
Editing the "config.plist" file:
System info for the test system (Dell Inspiron 3647/Vostro 3900) using HWInfo:
If you have any question regarding this thread, don't afraid to ask down below, Cheers!
Post edit changelog:
  1. (18/10/2023) Initial post with preparation for windows system tutorial.
  2. (18/10/2023) Added "System info for the test system (Dell Inspiron 3647/Vostro 3900) using HWInfo:" picture .
LENNYYYYYYYYY!!!!! WHERE R U BUOYYYYY??????
  •  Laptop:
    • Current
      • Spoiler
        Lenovo ThinkPad X1 Yoga Gen 8 | i5-1335U | 16GB LPDDR 6400MT/s Soldered | WD SN810 1TB NVMe (Win11) | 14 inch 1200p IPS 500 nits panel | Intel AX211 | 65W USB-C PD adapter | Aliexpress DIY Thunderbolt 3 eGPU dock with JieShuo RTX 3060M 12GB
    • Retired
      • Spoiler
        Heavily modified Lenovo ThinkPad T480 | i7-8550U | 2x 16GB Teamgroup DDR4 3200MT/s | Custom FCBGA 595 to Oculink 2.0 @ PCIe 3.0 x4 (using removed nvidia MX150 dGPU pinout) | 14 inch 1080p IPS 350 nits panel | 7 Row classic keyboard mod (from T25) | 512GB Samsung PM981a NVMe SSD (Win10) + 256GB WD SN520 2242 NVMe SSD (Manjaro; on WWAN slot) | Intel AX210NGW | 65W USB-C PD adapter  | Oculink 2.0 to PCIe x16 DIY dock eGPU with JieShuo RTX 3060M 12GB
  • Workstation:
    • Current - Repurposed as Homelab Dev Server
      • Spoiler
        AMD EPYC 9454P 48C/96T | Tyan Tomcat HX S8050 (S8050GM2NE) Socket SP5 | 8x32GB (256GB) Kingston Fury Renegade DDR5 4800MT/s RDIMM | Colorful iGame RTX 4080 Advanced OC (windows VM) | PowerColor RX 6600XT Fighter (MacOS VM) | 2x Intel Optane M10 64GB (RAID 1, Proxmox) | 4x Samsung 980 Pro 1TB (RAIDZ1, VM storage) | Nvidia Mellanox ConnectX-4 LX 25Gb SFP+ PCIe x8 (MCX4111A) | Seasonic Prime TX 1600W | Thermaltake Core W100 case | Enermax LIQTECH TR4 II 280mm AIO (SP5 Kit) |8x Deepcool TF140S Fan
    • Retired
      • Spoiler
        Intel Xeon E5-2650v3 10C/20T (locked all core 3GHz) | Dell ALienware Area 51 R2 Motherboard (MSi MS-7862) LGA 2011v3 with modded BIOS (ReBAR enabled) | 4x16GB (64GB) SKhynix ECC LRDIMM 2666MT/s Quad Channel | Colorful iGame GTX 1070 Flame Ares U-TOP | Samsung PM981a 512GB NVMe SSD (Win10) + TeamGroup MS30 M.2 SATA 512GB (Manjaro) | Mellanox ConnectX-3 OCP 2.0 NIC (with PCIe adapter) |  Thermalright AXP-100H Muscle CPU cooler (hacksawed to work with LGA 2011v3) | PowerUp Raptor 1633 case + 6x Deepcool RF-120FS case fan | IndoCase 500W 80+ Silver PSU (Rebranded & binned up Gamemax GM-500).
  • Homelab AIO server:
    • Current - Repurposed as Backup server
      • Spoiler
        AMD Ryzen 9 3900 (OEM CPU, got it from AliExpress) | Asus Prime B550-Plus AC-HES | 4x16GB (64GB) Samsung DDR4 3200MT/s ECC UDIMM | 2x Intel Optane M10 64GB (RAID1, TrueNAS Scale) | 6x Seagate SkyHawk 8TB (Bulk storage; RAID Z1; Alhua rebranded drive) | Asrock ARC A380 6GB Challenger OC (Terminal + Transcoding GPU) | Mellanox ConnectX-3 OCP 2.0 NIC | Deepcool Gammax C40 (dual fan) | IndoCase IC4008 4U rackmount case + 5x Deepcool XFAN120 + 2x Deepcool XFAN80 | IndoCase 800W 80+ Silver PSU (Rebranded & binned up Gamemax GM-800) | Samsung Galaxy S10+ 5G (5G backup uplink for Router VM).
    • Retired
      • Spoiler
        Intel Xeon E5-2695v3 14C/28T (force dynamic turbo all core up to 3GHz) | Huananzhi X99-TF-Q (Q87 chipset) LGA 2011v3 with modded BIOS (ReBAR & all core turbo enabled) | 4x32GB (128GB) Samsung ECC LRDIMM 2133MT/s Quad Channel | Nvidia Quadro NVS 295 (via M.2 E key riser; for basic display) + Dell GTX 1070 OEM (transcoding GPU) + Sapphire Pulse RX 470D 4GB (MacOS Ventura VM) | 2x Kingston A400 120GB (mirrored; TrueNAS SCALE) + 6x Samsung PM981a 1TB (VM storage; RAID Z1) + 7x WD Purple 4TB (Bulk storage; RAID Z1) | Mellanox ConnectX-3 OCP 2.0 NIC (with PCIe adapter) | Alseye M90 CPU cooler (hacksawed to work with LGA 2011v3) | IndoCase IC4008 4U rackmount case + 5x Deepcool XFAN120 + 2x Deepcool XFAN80 | IndoCase 800W 80+ Silver PSU (Rebranded & binned up Gamemax GM-800).
  • DIY Router:
    • Current
      • Decommisioned, current router system is running on current AIO Homelab server as VM (Modemsofmen ROOTer GoldenORB OpenWRT 22.10).
    • Retired
      • Spoiler
        HP EliteDesk 800 G1 SFF Prebuilt | Intel core i5-4460T | 4x 4GB Samsung DDR3L 1600MT/s UDIMM Dual Channel | 1x Kingston A400 120GB (ROOTer GoldenORB OpenWRT 22.10) | Mellanox ConnectX-3 OCP 2.0 NIC (with PCIe adapter) + Realtek RTL8125 2.5GBe PCIe NIC + Intel i210 SFP PCIe card with Mikrotik SFP ONU module (for WAN, my default ISP modem sucks) + Fibocom L860 4G modem (with USB 3.0 adapter, for WAN redundancy).
  • Desk setup:
    • Spoiler
      viewsonic VA2732-H 27 inch + VA2215H 22 inch (portrait) 1080p 75Hz IPS monitor | DIY sound system with 2 50W DIY bookshelf speaker | Senheisser HD 600 Headphone | Keychron K1 SE keyboard (Low profile Gateron brown) | Lenovo ThinkLife WLM210 mice | Samsung Galaxy S8+ (used as a Webcam LOL).
Nice
Won't a simple PCie adapter work ?
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
2 minutes ago, PDifolco said:
Nice
for older motherboard like AMD AM3+ or Intel Haswell based motherboard and older, you can't directly boot from NVMe SSD because lack of NVMe boot argument in the BIOS firmware, this guide is used to fix the issue. Meanwhile for use as basic data drive (not a Boot drive), you can plug it in any PCIe-compatible motherboard and OS (Windows 7 with latest patch and NVMe driver installed or Linux mainline kernel 3.3 onwards)
  •  Laptop:
    • Current
      • Spoiler
    • Retired
      • Spoiler
  • Workstation:
      • Spoiler
    • Retired
      • Spoiler
      • Spoiler
    • Retired
      • Spoiler
  • DIY Router:
    • Current
    • Retired
      • Spoiler
  • Desk setup:
    • Spoiler
5 minutes ago, PDifolco said:
Nice
Meanwhile, some Chinese vendor that produce "brand new" motherboard for older platform added the NVMe boot arguments in the BIOS firmware, as far back in Intel Sandy Bridge / Sandy bridge HEDT motherboard they produced (Intel X79 and C602, and consumer B75, H61, Z79, etc). Some higher end motherboard from "branded OEM" in the Intel Haswell era, like HP Zx40 series (Z440/Z640/Z840) workstation, Dell Alienware Area 51 R2, and some consumer Z97 motherboard got BIOS update that add the NVMe boot argument capabilities.
  •  Laptop:
    • Current
      • Spoiler
    • Retired
      • Spoiler
  • Workstation:
      • Spoiler
    • Retired
      • Spoiler
      • Spoiler
    • Retired
      • Spoiler
  • DIY Router:
    • Current
    • Retired
      • Spoiler
  • Desk setup:
    • Spoiler
