i’m not too sure yet if this is just for gta or other games how ever i have finished building my pc and have a rtx 4060ti and a amd ryzen 7 5700x
i spent all of yesterday downloading gta and im not sure what went wrong or if i am missing something to do with the gpu
it was my first build so im sure i am missing somthing
https://linustechtips.com/topic/1536161-gta-graphical-problems/
6D86DEA4-1381-4AFE-9392-BE2C547206EC.mov
Mi amigo says it's about drivers. Update and reinstall your drivers
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1536161-gta-graphical-problems/#findComment-16170792
1 minute ago, Bodger said:
i’ll give this a try once i’m home from college
You should use DDU to uninstall your old drivers
Display Driver Uninstaller (DDU) download version 18.0.6.8 (guru3d.com)
Total: £1040.95
https://linustechtips.com/topic/1536161-gta-graphical-problems/#findComment-16170808
Im not sure but others can advise both yourself and me, your RAM, it should work better seated in the slots one over. You have it in slots 1 and 3 instead of 2 and 4. Seat RAM in slots 2 and 4 for better performance from the RAM
and an M.2 drive may also increase performance, not sure if you have one with the heatsinks in the way but i do see a sata cable
Also yes driver update/reinstall like everyone else has said should solve some issues
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1536161-gta-graphical-problems/#findComment-16170831
atm i have my gta running off my m.2 due to forgetting to get my hardrive out, ill move the ram over later as well and get back to you once its all done
https://linustechtips.com/topic/1536161-gta-graphical-problems/#findComment-16170835
Grand for the M.2! should have buttery quick loading times. For the RAM i doubt there will be too much difference to be honest, but there should be a very small uplift in performance, you probably wont notice it, but will also be nicer aesthetically (imo) on top of that. But for the game performance issue, other than drivers im not sure, it looks like everything is seated properly and should be running right from a hardware POV, from what i can see at least
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1536161-gta-graphical-problems/#findComment-16170843
