upgrade Upgrade Planning Help ^^
Solved by SorryBella,
31 minutes ago, Slania said:I am just trying to plan my upgrades so I can plan my budget accordingly. It's better (imo) to have a goal of certain pieces and wait/work for favorable conditions
It works for long depreciation products like home but it doesn't work for short depreciation products like tech. You really should spend in a lumpsum, itll be financially better for you to a point.
