Do not use any cable that did not come with your PSU. They are not compatible.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1534909-help-psu-cables/#findComment-16162414
23 minutes ago, Zuruox said:
So I have a 6 pin PSU to molex cables that I want to use but my PSU only has an 8 pin connector in it, is it safe for me to plug it in? The connector does seem fit though missing the last two pins
What's the brand and model of the PSU and what CPU and GPU do you want to power with it?
8 pin on the PSU side is usually for CPU and GPU. Don't put a sata/molex cable in there!
https://linustechtips.com/topic/1534909-help-psu-cables/#findComment-16162431
The cable might physically fit but it could be wired completely differently. Not worth the risk.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1534909-help-psu-cables/#findComment-16162432
