Ideal fan configuration
Solved by filpo,
2 minutes ago, Thomas Peterson said:what's the ideal config for the fans for cooling
i'd use the front 3 as intake, same with the back fan and then exhaust with the top rad
3 minutes ago, Thomas Peterson said:Also how do I cable manage all this and get them all pwm controlled?
plug the fan cables into their headers (you should've gotten fan splitters with the noctua fans if you need teh splitters)
3 minutes ago, Thomas Peterson said:do I cable manage
just pass most of the cables through one place through the back of the case
or do as I do and don't cable manage at all (I try but I don't succeed
