Cooler
Go to solution Solved by TatamiMatt,
11 minutes ago, FPS_Lego said:
Whats a good Budget Cpu aftermarket air cooler that cools well? Got a ryzen 3 3200g but planning to upgrade to a ryzen 5 5600x or ryzen 5 5600 later on
Most of thermalrights stuff, id recommend Phantom spirit 120 or AK620, a little bit pricier, similar performance and a little quieter
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1534126-cooler/#findComment-16156368
Honestly, the cooler that comes with the 5600 is really good for free.  Another option for you if you wish to save money.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1534126-cooler/#findComment-16156374
at first it might be fine, but later on you can face overheating issues. Plus spending a little extra on a cpu cooler can save your cpu from overheating and increase its life span
https://linustechtips.com/topic/1534126-cooler/#findComment-16156406
Not exactly.  Thermal throttling is what saves the CPU from burning out, which it will do irregardless of what cooler is on it.
Are you using the Wraith Stealth with your 3200g?
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1534126-cooler/#findComment-16156501
Yeah currently using it, while gaming its around 70C and 49C at idle, not so good
https://linustechtips.com/topic/1534126-cooler/#findComment-16157644
I used Hyper 212 Turbo on my 5600x long while ago, it was good enough.
Refresh before you reply
https://linustechtips.com/topic/1534126-cooler/#findComment-16157656
49C idle isn't great but 70C gaming is, but I guess you're not playing anything intense with a 3200g.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1534126-cooler/#findComment-16157892
Yeah. I did some digging for a good budget cooler, found one on amazon where there is a discount, with 4k buyers and really good reviews. No clearence issues. Its the coolermaster HyperT20, and it is a little smaller in size compared to the other ones but the cooling is great. with the ryzen 5 5600 it idles around 25-30C and while gaming about 57-65C which is pretty great, but also the ambient temperature of the room, the airflow matters. so i think imma get that. till i get the ryzen 5 5600 i think the cooler will run wpretty cool with my 3200g. Thanks tho!
https://linustechtips.com/topic/1534126-cooler/#findComment-16159020
or just get a thermalright PA120SE
Or an ag400/ag620
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1534126-cooler/#findComment-16159033
Or an ag400/ag620
Ive checked the ag620, idk there can be a clearence issue between the cooler and the ram but I will check. I have a corsair spec01 case so it will fit fine between the side panel right? as some coolers as so chunky that they touch the side panel
https://linustechtips.com/topic/1534126-cooler/#findComment-16159136
The ag400 can fit. So can the thermalright Assassin X 120 refined SE
Total: £1040.95
https://linustechtips.com/topic/1534126-cooler/#findComment-16159140
