I keep getting a post code of 0d on a nas project that I’m currently working on the build is a threadripper 1950x with a asus rog x399 E gaming motherboard I’ve updated the bios and I’ve reseated the ram I’m concerned that the cpu may be broken because it was second hand off of eBay and when it came it had thermal paste on the pads but before I try to get a refund I want to know if there is anything I haven’t tried
https://linustechtips.com/topic/1533855-post-code-0d/
Do you have the AMD torque wrench?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1533855-post-code-0d/#findComment-16154303
I was coming here to ask that
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1533855-post-code-0d/#findComment-16154354
32 minutes ago, 10001110101 said:
No
That's a large CPU that is very sensitive to mounting pressure and what order you torque the screws in. I'd put money on it not being properly mounted before it being a bad CPU.
1.5 N/M is the torque spec for the screws. Do the far single screw first and you should have better luck with your mounting pressure.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1533855-post-code-0d/#findComment-16154374
Do you have a suggestion for how to get the correct pressure or should I just buy a one
https://linustechtips.com/topic/1533855-post-code-0d/#findComment-16154421
Buy one or another small torque wrench. Or borrow someone else's small torque wrench.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1533855-post-code-0d/#findComment-16154423
