Dual tower cooler
Go to solution Solved by TPCEA,
10 hours ago, Idkwhattodowithmylife said:
Is a dual tower cooler a bit excessive for a 5700x?
There is no such thing as excessive when it comes to cooling, unless you spend more than you can afford, or buy high- priced garbage. 😉 Also, buying a cooler that's more powerful than you need increases the usability factor for future PCs.
Not at all.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1533790-dual-tower-cooler/#findComment-16153857
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1533790-dual-tower-cooler/#findComment-16154191
