Ethernet trouble
Go to solution Solved by Sky_Fire,
2 minutes ago, CaptainQuirk26 said:
I assume you've tried the tried and true method of restarting?
i did, but i forgot to do the other tried and true method of just letting it be on for an hour and suddenly it works again
Are you plugging direct to mobo if you have that option or a NIC card?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1532246-ethernet-trouble/#findComment-16142905
