Fan Arrangement
Go to solution Solved by TatamiMatt,
1. Positive pressure does two things, 1-creates a pressurised area within the case which helps force air into all the nooks and crannies to absorb heat and 2-creates airflow out of the tiny holes and vents in the case due to the pressure, this ensures no air is drawn into the case through open holes with no dust filters like vents and that. Which in turn will keep your pc dust free for longer
2. Positive pressure will indeed decrease temperatures as you will have more air, i.e. a higher density of air, inside the case to absorb heat
3. I have no prior knowledge on this point, but, from what i can see theyre nearly identical. The LE520 has 5mm less tubing but 410 vs 415 is negligible, the only other differences are the RGB on the 520 compared to the single colour on the 500, and the 520 has a more power efficient pump and fans, running at a lower wattage. Although the extra RGB potential of the 520 pretty much negates this, but when your looking at a difference of less than a dozen watts all around, this is also negligible, so go with what you like best.
Im using an "Antec DF600 FLUX" Case, I have a few questions:
1. Why should the case have positive pressure instead of neutral pressure? Will positive pressure affect certain parts or cables
2. Will positive pressure decrease the temperature?
3. What is the difference between the "Deepcool LE500 240mm" and the Deepcool LE520 240mm"? (2 Fan AIO Coolers). Also do they have a cable for controlling the RGB?
Pure Laptop Gaming found here, gaming and video editing to be exact
Months of searching for the best and optimal gaming and video editing laptop
(I may sound dumb but that's part of the process, learning is good always)
By the scheme of the text color, I am Indian, with a budget
https://linustechtips.com/topic/1532201-fan-arrangement/
More air for your components is normally better
nope
most likely
They will both probably perform the same. get the one that's cheaper
yes they should. But make sure the mobo you're getting has an argb/rgb connector
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1532201-fan-arrangement/#findComment-16142524
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1532201-fan-arrangement/#findComment-16142526
LE500 is static color while LE520 is ARGB so you can change the color yourself
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
https://linustechtips.com/topic/1532201-fan-arrangement/#findComment-16142527
Thank you guys!
https://linustechtips.com/topic/1532201-fan-arrangement/#findComment-16142545
