umm so ye HELP!
atm im using after effects cs6 11.0.2.12
i got a gtx titan and i was using sony vegas pro 12
and the gpu assisted rendering is doing a difference
but in after effects
it doesn't seems to do a loot
so my question is
what can i do to make a difference
a list of file formats that takes advantage of cuda cores
and a list of effeckts that's has an advantage from cuda cores
would be AWESOME
any any other tips on how to speed up render times would be grate
(and yes i have added the gtx titan to the raytracer_supported_cards.txt file and yes it woks in after effects but not more than 1-5%.... soooo ye.....)
