Just moved into a new apartment. The keystones in the rooms are wired up, but the line drops at the ONT are not finished. I wasn't sure what standard they use in China so I pulled the plate off the wall. What order should I terminate the rj45 based on thes photos?
https://linustechtips.com/topic/1531955-wiring-standard-help/
Redo the wall plate, it has orange/white-orange transposed. Other than that (for some reason) they used T-586A.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1531955-wiring-standard-help/#findComment-16140763
17 minutes ago, Bad5ector said:
Sure looks like T-586A to me...
I mean if you follow the guide on the keystone there, it clearly shows that it's T-586A. Apologies if you're colour blind.
Not color blind, just confused why it doesn't match this... Unless the wires in the keystone are doing some gymnastics and cross all over the place before getting to the respective pins.
https://linustechtips.com/topic/1531955-wiring-standard-help/#findComment-16140808
They cross in the plate and line up in the end
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1531955-wiring-standard-help/#findComment-16140818
That's my guess, in order to make it simpler for the installer. Once you terminate the other end, check with a cable tester for pinout.
Network:
https://linustechtips.com/topic/1531955-wiring-standard-help/#findComment-16140820
D'oh, didn't even notice that one. Good catch.
I mean, is that really that far of a stretch? Unless China has a whole different standard but still calls them the same. TBH, whenever I wire up my stuff I just follow the keystone guides for B, and never question it or look too closely. Only when I'm crimping cable do I pay attention to a diagram, since I have a simple mind.
https://linustechtips.com/topic/1531955-wiring-standard-help/#findComment-16140822
So an update, I ended up pulling most of the plates off the walls (except behing the TV, need help pulling it off the wall) and EVERY plate was wired differently than the others. Ended up redoing all of them and now have a functioning AP in the bedroom. Not sure what intern they had doing the drops, but what a mess.
https://linustechtips.com/topic/1531955-wiring-standard-help/#findComment-16141552
