Try a new cable.  What GPU are you using?  What monitor?  Rest of specs?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1531386-please-help/#findComment-16136539
Try powering the monitor up with no display cables connected. If you see the vertical lines, then your display is physically damaged. (This is extremely unlikely to be caused by software alone.)
Power the PC and monitor off, reseat the display cable at both ends, and try booting up again.
If the lines are still there, try another computer or monitor.
https://linustechtips.com/topic/1531386-please-help/#findComment-16136541
I see one really tiny scratch but i dont know if its the issue. its really hard to see though
https://linustechtips.com/topic/1531386-please-help/#findComment-16136554
You should know if your monitor has received damage.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1531386-please-help/#findComment-16136555
3 minutes ago, Jajo said:
i dont remember anything like this
Then you're looking at what @Needfuldoer said above.   Time to test things.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1531386-please-help/#findComment-16136564
9 minutes ago, Jajo said:
i reaseted the hdmi and it seems to be gone now. what if the issue comes back?
It may be the cable or a port on the card or monitor.  Can't know without more testing, but glad it's fixed for now.
If it comes back, look into a new cable or checking the ports for looseness, etc.
If it stays though, do the testing mentioned earlier.  Something may be dying, can't know without testing.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1531386-please-help/#findComment-16136594
