Hi all!
I am soon to purchase a new computer after years of saving. It's primary purpose is going to be gaming, but I am studying a Level 3 BTEC Extended Diploma in Computing and AS Mathematics at college (UK) and we are working with virtual machines to set up and protect networks and some minor video editing/rendering. I am also studying for the Cisco CCNA and CCLI and hope to go into cyberspace security.
I have designed this computer from my own experience with designing computer for multiple purposes to fit a certain budget; but one think which I have no experience in is water cooling. Therefor I have put together a list of components to which i believe will fill my purpose.
I ask only one thing, I accept all forms of criticism but there is a line between criticizing and being an d**k.
Watercooling components for those who do not wish to trawl through the PCPartpicker page:
My Questions:
Q1. The obvious, will this work?
Q2. Will the AX860i be enough power to XFire a 290x, both with water cooling?
Q3. Will the pump be powerful enough to perform the previously mentioned?
Q4. As for the motherboard I intend on buying an armored version of the Sabertooth, whether I buy the first revision or they release an armor kit for it. Will I have enough room in my Corsair 450D for the 360mm radiator?
Q5. Does anyone object to my parts list? If so say what could be improved.
I do not wish to take up too much of your time with this and i appreciate all of those who comment's help.
One final thing is that I will be purchasing white individually sleeved cabling for my PSU. Can't go all out in a system without "dem cables".
With thanks,
Radioactivetux
-Oliver Legg
https://linustechtips.com/topic/153136-water-cooling-help-needed/
Hi all!
PCPartpicker Link
XSPC RX360 Black 360mm Radiator
AlphaCool Nexxxos UT60 240mm Radiator
EK-Supremacy Acetal/Nickel CPU Water Block
EK-FC R9-290x GPU Water Block
7x Monsoon (ID 3/8 OD 1/2) Compression Fittings (White)
MasterKleer 59199 PVC Tubing (3/8ID) 10ft (White)
EK-Ekoolant 1000mL (Clear)
EK-D5 X-RES TOP 140 CSQ Acetal Pump/Reservoir Combo
My Questions:
With thanks,
Radioactivetux
-Oliver Legg
Ok looks good, however I would say don't get that RAM as you don't need 16Gb for gaming and the extra few megahertz won't make a difference, also you'll need more fittings, it it's 2 per component.
And 1 last thing, that pump/res isn't actually a
Pump, it's something that goes onto an existing pump to make it look good, the best pump is something like the swift tech mcp655 and any res.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
Thanks for that, would have bought it blindly expecting it to pump ;) and with the ram I want it so that if i choose to upgrade for another purpose I will have the expandability. If I purchase 8GB of RAM then I can only upgrade to 16, but with 16 I can upgrade to 32. In my current rig I have 8GB of Kingston HyperX Predator ram and some of the tasks I perform seem to max it out.
