Did you connect all the wires correctly? Does it POST? Any errors on the motherboard readout?
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
Have you plugged your monitor to the power socket?
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
Do you have intergrated graphics turned off? Sometimes if they're on your bios will show up through onboard graphics ports and then windows will load of the graphics card once booted but, for that you have to have windows installed and the gpu drivers.
So I spelt something wrong in my post... I don't care I don't read through what I write and I type very quickly.
Intel 3770k stock, MSI Z77A-GD65, MSI GTX 760, Corsair Vengence DDR3 1600Mhz 16Gb, Corsair RM 550W, Samsung 830 256Gb, some random hdds.
