Should still work I reckon
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/153009-will-sli-still-work/#findComment-2043255
I can't see why not, maybe a clearer picure of the whole back of the card? But it looks like it'll work
ACS Systems - Jason Neal
My "Danger Den" PC: i7-4960x @ 4.5Ghz, ASUS X79 Deluxe, 3x GTX Titan Black, 6x m4 512GB, 64GB Corsair DDR3-2400, Corsair AX1500i
Black Beauty Workstation/LAN PC: i5-4570 @ 3.79 GHz, ASRock Z87E-ITX, XFX Double D R9-280 (Non-X), GSkill 8GB DDR3-2400
https://linustechtips.com/topic/153009-will-sli-still-work/#findComment-2043261
It's visible from the pic it's the little gold piece to the left.. on the bottom right side of that gold piece you can see it as a little white spec
it should work fine. The connector makes contact with a lot more surface than the very tip of the sli finger. :)
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/153009-will-sli-still-work/#findComment-2043318
