Not Optimum Mode
Solved by kerriya,
2 hours ago, kerriya said:i just bought 3080 but monitor only has a vga so i decided to use an adapter and well it works but every time i turn on pc it shows this message and also screen feels kinda blurry and weird. yes i installed all the drivers.
edit: i fixed it! i just changed it from the nvidia control panel and it worked
i fixed it
