Hi peeps...
Need some guidance and wisdom...
I am running 9th Gen i5 with 32Gb (3200) RAM and an NVME drive, paired with a GTX 1070...
I basically only play Warzone 2.0 with occasional MW2 - and I'm dropping frames...
I'm looking at getting a new GPU, but just can't decide what to get...
I've only ever had Nvidia, but AMD seems to be the better choice...
Any advice would be awesome...
https://linustechtips.com/topic/1529935-help-me-pick/
Does your mainboard support reBAR?
Please, provide a reasonable (for you) budget for the upgrade.
Not English-speaking person, sorry, I'll make mistakes. If you're kind, maybe you'll be able to understand.
If you're really kind, you'll nicely point that out so I will learn more about write in good English.  🙂
https://linustechtips.com/topic/1529935-help-me-pick/#findComment-16125484
how is your temps and GPU/CPU usage?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1529935-help-me-pick/#findComment-16125530
Rebar isn't supported by his components, too old.
2 hours ago, RSchoenknecht said:
Hi peeps...
What drives do you have?  SSD or HDD?  If HDD, look at replacing.
1070 is a good pairing with that CPU.  If you get a new GPU, you're going to have a CPU that can't keep up.  You have no hyperthreading either.
Dropped frames aren't always a GPU issue, look at your entire data pipeline to see what else can be an issue.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1529935-help-me-pick/#findComment-16125591
Temps are all good, in the mid 60 deg region, have a nice tower cooler on the cpu and stock gpu cooling... Running medium settings on Warzone 2.0 and average FPS is mid 60's but the odd drop below is what is bothering me... only run at 1080p
https://linustechtips.com/topic/1529935-help-me-pick/#findComment-16125699
could be CPU related issue as far as I'm concerned, I'm not 100% on how well a 1070 can run Warzone, but it shouldn't dip very noticeably to lag or anything
BR games are more demanding on CPU than other games
current PC:
https://linustechtips.com/topic/1529935-help-me-pick/#findComment-16125751
