5 minutes ago, Funnygibbon888 said:
What PSU should I get for AMD 5 7600, msi 6650xt, asrock b650 Hdv/m.2, 500gb Ssd, 2x8gb ddr5 ram, couple of fans, and that’s about it. Suggestions?
A solid 650w would do the trick. The RM750e is nicely priced at 99 dollars however with good reliability and efficiency.  750w is overkill for your system but having some extra power gives you an option to upgrade to a faster GPU later, the AMD 7600 CPU is very fast and would pair nicely even with a 4090 or 7900XTX.
https://linustechtips.com/topic/1529406-psu-question/#findComment-16121844
