Hi Timmy187,
I am not an expert, but I have done a quick Internet search on your behalf regarding Secure Boot and found the following suggestions:
I do hope that some of these ideas can help.
To fix the issue of secure boot enabled in BIOS but not in Windows, you can try the following steps12345:
  • Update your BIOS to the latest version. Check your motherboard manufacturer's website for any available BIOS updates.
  • Disable CSM (Compatibility Support Module) in your BIOS settings. This may interfere with secure boot.
  • Enable secure boot properly in your BIOS settings. Make sure you save the changes and restart your computer.
  • Restore factory keys or load setup defaults in your BIOS settings. This may reset the secure boot state.
  • Scan your computer for malware. Some malware may disable secure boot.
https://linustechtips.com/topic/1528348-secure-boot-help/#findComment-16112583
