Building a high end system
Solved by Dedayog,
That motherboard is an overspend and dead waste of money for a dead end platform.
I'd go with a 7950x3d personally. Easier to undervolt and tame, as that DR Pro 4 won't even dent that 13900k.
PSU - overkill on power, I'd grab a 1000w platinum from SuperFlower or the like.
Not sure if the 7900XTX is helpful for AI, may need to move to Nvidia.
