I need a device to send me a message/email/notification when the power comes back
By
Bassem
in Programming
in Programming
Solved by Bassem,
Found an easy solution:
I have a Tapo smart plug, I used IFTTT to send me a notification when the power came back on, and it's working nicely
Note: if you want try this you need to set the default plug status to ON, and in IFTTT (IF the Device is on THEN Turn it off AND send a Notification)
Featured Topics
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting3 -
2
2
6
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
3
7
2
