PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (€140.95 @ Megekko)
Motherboard: MSI PRO B550M-P GEN3 Micro ATX AM4 Motherboard  (€94.90 @ Amazon Netherlands)
Memory: G.Skill Aegis 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (€52.90 @ Amazon Netherlands)
Storage: Samsung 980 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€56.90 @ Amazon Netherlands)
Video Card: XFX Speedster QICK 319 Core Radeon RX 6750 XT 12 GB Video Card  (€383.00 @ Amazon Netherlands)
Case: Deepcool MATREXX 55 MESH ATX Mid Tower Case  (€62.90 @ Azerty)
Power Supply: SeaSonic G12 GM 650 W 80+ Gold Certified Semi-modular ATX Power Supply  (€86.85 @ Azerty)
Total: €878.40
Generated by PCPartPicker 2023-08-22 22:06 CEST+0200
This might do the job if you stick to 1080p and 1440p at most.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
https://linustechtips.com/topic/1527770-first-pc-build/#findComment-16106243
42 minutes ago, ItTakes2ToMango said:
This is a great computer if you plan on upgrading the GPU later on. 6600 isn't gonna cut it for what you want in MC.
what kind of MC are you playing? 6600 is plenty for MC
current PC:
PC configs I used before:
https://linustechtips.com/topic/1527770-first-pc-build/#findComment-16106292
6 hours ago, ElectricSteve said:
Don't judge me
If someone can teach me build, i would actually add them on EGS.
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  (€192.80 @ Azerty)
CPU Cooler: ENDORFY Fera 5 Dual Fan CPU Cooler  (€35.65 @ Amazon Netherlands)
Motherboard: ASRock B550M Pro4 Micro ATX AM4 Motherboard  (€110.95 @ Megekko)
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€49.90 @ Amazon Netherlands)
Video Card: XFX Speedster SWFT 309 Radeon RX 6700 XT 12 GB Video Card  (€362.95 @ Megekko)
Case: Deepcool MATREXX 40 3FS MicroATX Mini Tower Case  (€46.74 @ Amazon Netherlands)
Power Supply: MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply  (€69.90 @ Amazon Netherlands)
Total: €921.79
Generated by PCPartPicker 2023-08-23 04:10 CEST+0200
snuck a 5700X upgrade which would be really good for frame time on this game. Also keep your eyes on 5800X3D in used market, we might be able to snag that instead with a bit of overbudget. As of writing, 5800X3D is 300 euros.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1527770-first-pc-build/#findComment-16106606
14 hours ago, ItTakes2ToMango said:
Heavily modded with shaders? You won't be getting 60FPS - guarantee you that one.
do you play heavily modded MC with shaders?
current PC:
https://linustechtips.com/topic/1527770-first-pc-build/#findComment-16107019
Yes, and I can't get a consistent 60 FPS on heavily modded MC with shaders. Specs below. It will be dipping into the 40s guaranteed.
I sell teeth and teeth accessories 🦷
https://linustechtips.com/topic/1527770-first-pc-build/#findComment-16107080
Total: €921.79
Why would i prefer this one: https://nl.pcpartpicker.com/product/RFGbt6/xfx-radeon-rx-6700-xt-12-gb-speedster-swft-309-video-card-rx-67xtyjfdv
over this one: https://nl.pcpartpicker.com/product/c3RYcf/
https://linustechtips.com/topic/1527770-first-pc-build/#findComment-16107234
36 minutes ago, ElectricSteve said:
Frankly its just a universal pick for 6700XT or 6750XT. Pick whichever are the cheapest.
https://linustechtips.com/topic/1527770-first-pc-build/#findComment-16107292
have you considered CPU load?
current PC:
https://linustechtips.com/topic/1527770-first-pc-build/#findComment-16107416
15 minutes ago, ItTakes2ToMango said:
on a 3600x? lol of course not. GPU usage is always higher
Not concerned with it at all to be honest - this post ain't for me
I know, but have you really checked? (though sounds like you did)
current PC:
https://linustechtips.com/topic/1527770-first-pc-build/#findComment-16107471
Just now, ItTakes2ToMango said:
Yeah, but it was many months ago
I'd imagine mods to heavily impact CPU, since there's the game, and you put extensions on top of it basically
current PC:
https://linustechtips.com/topic/1527770-first-pc-build/#findComment-16107487
there is no 50, both are 6700XT one is just more expensive,
so the answer remains the same as @SorryBella said, buy the cheapest
current PC:
https://linustechtips.com/topic/1527770-first-pc-build/#findComment-16107517
