Motherboard corner opened up. Broken traces?
LoopS
Bought a second hand motherboard. and seems during shipping something went horribly wrong. i couldnt find any traces off the bat under the microscope. Havent received the PSU and CPU yet so waiting on those in order to test out. Thoughts?
that miiight actually be ok.  Either it works or it don't. Keep us updated!
I would generally recommend you knife off the damage if you are sure there are no needed traces on it, as there would still be internal layers for ground and possibly power.
otherwise it poses a risk of shorting it out
i do have a top down image as well. let me share it here. Its quite disappointing receiving it like this to be honest. however i suppose ill still need another week to test if it works.
make a shipping claim even if it works, it’s quite severe damage
Yup. already made the claim as luckily it was insured shipping. Fingers crossed though.
Will update if it works or not soon
That CPU socket doesn't look to be doing well either
Intel Core i9-10900X, Asus TUF X299 Mark 1, 64GB DDR4 3200MHz, Asus GTX 1080 Strix, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, DC Assassin III, Meshify 2
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 24GB DDR3 1600MHz, Asus GTX 1080 Strix, 500GB, 250GB & 120GB SSD, 2x 4TB & 2x 2TB HDD, Fractal Define R5
PC 2: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
PC 3: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 16GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
That cpu socket looks destroyed. I doubt this board still works at all.
Yes. i bought the Motherboard knowing it was a damaged socket as i was planning to replace the socket
If you've got the skills go for it
However this board is probably cooked regardless so if this was ebay or something flag it as broken on delivery
Yup already started a return on the product. Bit too much to handle. Well honestly maybe not too much skill with it. But this was supposed to be the first mobo i was going to use after replacing a socket. Been practicing on some dinged up ones recently. Cheers!
Oh my how did that even happen i dont comprehend just lose of words. i wish you luck in your endeavors. i got into tech repair so seeing that gives me nightmares.
How much did you pay for the motherboard and was it listed as damaged when you bought it OP?
CPU : Ryzen 7 7800X3D @ -18mv all core except -13mv on Core 5 because its a pig.
CPU Cooler : Deepcool AK620 Zero Dark
Mobo : MSI B650M-A Wifi MATX
Ram : 32GB (2X16GB) Corsair Vengeance DDR5 6000MHZ CL34
GPU : Reference Design RX7900XT sold by Saphire running at 1050MV undervolt and +15% PL (355w)
Storage : 1TB WD SN770 + 2TB Samsung 970 Evo
PSU : Corsair HX750w Platinum
Case : Asus Prime AP201 All Mesh MATX
Case Fans : Arctic p12's everywhere i can fit them in , 7 In total.
Monitor : LG 27GP850-B.BEK 1440p Nano IPS 180Hz
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
Paid around 60 for it. listed as damaged socket only. photos on it were the same
