Network Switch Help
On 8/21/2023 at 8:09 AM, Acrozi said:Hello everyone,
Recently, I just got new lines ran of ethernet cable to different rooms in my house and now I have a total of 7 wired connections to the router but the router only has 4 ethernet ports. I know I need a switch but is there any switch that would keep the 250mbps ran to each and every one of those connections? Because from what I understand, the more connections, it will divide the total speed by the number of connections to the switch and I would like to know if there is a way to keep 250mbps to each connection.
If you know any products that can help me accomplish this too, please feel free to link them or what they are called.
They make 8 port unmanaged switches designed for that sort of thing. Proper managed switches get into hunderds/thousands of dollars (I have two $9k switches arriving soon, as an example...)
NETGEAR 16-Port 10/100/1000 Mbps Gigabit Unmanaged Switch Blue GS116NA - Best Buy
An example of a 16 port Gigabit unmanaged switch.
You're unlikely to need more than 1Gb unless you're already knowingly exceeding such between two devices (like you have two 2.5Gb or 10Gb devices you need the fastest communication between), otherwise 1Gb is more than plenty in my opinion.
The reason you'd want a managed switch is to do VLANNing/subnetting between those devices with certain access rules. If you just need them to be able to talk to one another and/or see the same WAN connection, then that's plenty.
Technically you can get slightly-managed small switches, but they're generally quite niche in their application and usually require some sort of setup. Unmanaged switches are truly plug and play.
