Looking for OEM or panel manufacturer for these two monitors.
SimplyChunk
Hey guys,
Bought this monitor the other week to replace my old Acer eBay special second screen.  The X= XE24HD 24" Full HD IPS 165Hz and I love it.
https://www.awd-it.co.uk/x-xe24hd24-fullhd-ips-hdmi-165hz-monitor.html
I've never had an IPS display before and never thought it would be much different to the TN panels I'd always had before but it's amazing.  So much so, that I now want to replace my aging Asus PG278QR with another from the line up.  The X= XPRO27IPS 27" 1080p 165Hz.
https://www.awd-it.co.uk/x-xpro27ips-27-ips-1080p-165hz-1ms-freesync-g-sync-dp-hdmi-gaming-monitor.html
I've had a quick look online for some info on both these panels to try and find out if the panels are made by the same manufacturer or not as I'd like to just make sure the 27" panel is going to 'pop' in colour like the little 24" does (My PG278QR looks really washed out in comparison)  I'm also aware that I'll be dropping back down to 1080p from 1440p on my main display but with current GPU pricing at the minute and the only 'real' upgrade to my 2070 Super from the nVidia side being £600 at the minute I think a drop in resolution wouldn't be all that drastic.  Plus I could probably get most of the £150 quid that the X= 27" will cost me back by selling the PG278QR
Anyways, thanks for your thoughts and answers in advance 🙂
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
