You do not need a dedicated RAID card ~ Your MOBO should supports RAID 0, 1, 5 & 10. Just check your MOBO's user manual to setup RAID.
I am looking into getting 2 samsung 840 evo 250 gb ssd`s and wanting to set them up in a raid 0 but I have no idea what raid card to get, please give suggestions. (try to keep it sorta low cost)
https://linustechtips.com/topic/152710-help-raid-set-up/#findComment-2039697
I did not know that, I will have to look into it. Thanks
Just looked and my motherboard does. Thanks again
Edited by ttGrant
https://linustechtips.com/topic/152710-help-raid-set-up/#findComment-2039720
http://linustechtips.com/main/topic/143549-how-do-i-setup-raid-0/
https://linustechtips.com/topic/152710-help-raid-set-up/#findComment-2039747
