Hello, I'm in the process of setting up an eGPU for my Lenovo ThinkPad L480 and could use some guidance. I'm looking for compatible parts and step-by-step instructions to ensure a smooth setup. Any assistance or recommendations would be greatly appreciated. Thank you!"
https://linustechtips.com/topic/1527031-external-gpu-related-help/
If your laptop has Thunderbolt of some flavor, buy a Thunderbolt GPU enclosure and test it.
If your laptop doesn't have Thunderbolt, don't bother. No one will be able to guarantee it will work (or work well/stable), it defeats the purpose of a laptop (portability), and it's expensive besides. Buy a used office PC and a GPU if you really must have a GPU in a system.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
I wouldn't recommend it either way, even if its a Thunderbolt eGPU. I spent a year daily driving one between 2016-2017 and testing it again in 2020 for several months using a Razer Core. There's a perceivable (measured using Overwatch1) 50ms extra input latency, even when using a display direct attached to the eGPU.
You can also run into the problem of an ultrabook not being designed to run the CPU at high usage for hours at a time, or in one case with the Lenovo ultrabook I tested in 2020, the heat from the CPU eventually causing the battery to overheat and shutdown the system (took 8-9 hours of straight gaming to do so).
The other solutions however are good, like Alienware's proprietary PCIe connection, or Asus'. Those first party solutions that use specialty connectors at least don't cripple themselves with latency, still not perfect.
The reality is the cost to buy an eGPU setup (excluding the GPU), you could probably get an i3 12100f rig and use that instead and get similar if not better performance. The good eGPU solutions aren't cheap.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
i do not care about the portability due to that i have multiple laptops and i dont want to buy a new pc and i dont have a thunderbolt port soo im thinking i could connect a EGPU using an m.2 slot
128GB M.2 SSD / PCIe NVMe, PCIe 3.0 x 2, 16Gb/s,
in WWAN slot as 2nd Storage, mutually exclusive with WWAN.
The wwan m.2 slot is in the top right
Guest
