i need some urgent help
Solved by _GLADIATOR,
1 minute ago, Uraveragemusicprod said:I really don't care if I lose everything I just need to be able to reinstall windows onto the SSD with the usb
Ok, first
1. connect the bootable USB to ur laptop
2. press f12 Dell, f9 for HP or just search on google (what is bootable key for e.g., lenovo laptop)
3. select ur USB drive & press enter
4. then refer the images below attached and make selection according to ur preference if u dont have a "product Key" just select the option "i dont have a product key" in image "6" select select "custom install"
5. then in image "7" select partitions and delete if u want to or if u have to to proceed further, then select "Next" and installation process will began.
