Budget: $5000-6000 AUD, Flexible
Country: Australia
Productivity: Matlab, Autodesk (Engineering/Designing Software)
Games: Stellaris, City Skylines, Hitman 3, Rainbow Six Siege, KSP2, RDR2
Existing Parts: Gigabyte M32U 3840x2160 4K HDR 144hz
Parts List
https://au.pcpartpicker.com/list/d8MJxH
CPU: i7 13700k
CPU Cooler: Corsair iCUE H150i Elite Capellix 75CFM 350mm
Motherboard: Asus PRIME Z790-A Wifi ATX
Memory: Corsair Vengeance RGB 32GB (2x16 GB) DDR5-6000 CL36
Storage: Samsung 980 Pro 2TB M.2-2280 PCIe 4.0x4 NVME SSD
GPU: Asus ROG Strix RTX 4070Ti
Case: Corsair iCUE 5000X RGB ATX Mid Tower Case
PSU: Corsair HX1000 1000W 80+ Platinum Fully Modular ATX
Current PC Total (Excluding Peripherals)= $5000 AUD
Peripherals
Mouse: Logitech Pro X Superlight Mouse
Keyboard: Undecided but would prefer a detachable number pad or a TLK keyboard and buy the number pad separately.
Chair: Secret Labs Titan EVO $900 AUD, Open to thoughts and recommendations
Notes
The main contention point with the build is the GPU. I am deciding between a RTX 4070ti or RTX 4080 but an RX 7900 XTX maybe a good alternative. I would like to hear your thoughts and recommendations for the build and specifically the choice of GPU. If a higher performance GPU is chosen like a 4080 should the CPU be upgraded to a i9 13900k. I would prefer most internal PC parts to be white, however colour is absolutely not a deal breaker. Also an additional monitor could be added within a few years. I am looking to put the PC together myself within the next month. If parts are recommended I would prefer sourcing them from Australian Stores like MSY, Centre Com, (PCCG) PC Case Gear, JB-HI-Fi Etc.
Edit: MATLAB Requires CUDA cores, therefore a Nvidia GPU is required
https://linustechtips.com/topic/1526960-advice-for-pc-build/
Cheaper SSD while still providing the same experience.
4070 Ti for 4K is going to be a problem in the future, 12GB VRAM is maybe the new standard for 1440p.
7900 XTX is a good choice but I'm not sure if any of your software requires CUDA cores or not, CUDA is only available in Nvidia GPUs.
Cheaper PSU, that PSU is way too overkill for this PC.
https://au.pcpartpicker.com/list/BckCJy
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($170.99 @ Amazon Australia)
Video Card: Gigabyte AERO OC GeForce RTX 4080 16 GB Video Card  ($1899.00 @ PCCaseGear)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($155.00 @
Monitor: Gigabyte M32U 31.5" 3840 x 2160 144 Hz Monitor  (Purchased For $0.00)
Total: $4171.84
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1526960-advice-for-pc-build/#findComment-16096690
I would run that build like this so that you get decent frame rates on some of the more demanding games.
PCPartPicker Part List
CPU: *Intel Core i7-13700 2.1 GHz 16-Core Processor  ($599.00 @ BPC Technology)
CPU Cooler: *Deepcool LS720 WH 85.85 CFM Liquid CPU Cooler  ($199.00 @ MSY Technology)
Motherboard: *Asus ROG STRIX B760-A GAMING WIFI ATX LGA1700 Motherboard  ($425.00 @ I-Tech)
Memory: Corsair Vengeance RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($169.00 @ Amazon Australia)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($249.00 @ Centre Com)
Video Card: *Gigabyte AERO OC GeForce RTX 4080 16 GB Video Card  ($1899.00 @ PCCaseGear)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  ($185.00 @ PCCaseGear)
Power Supply: *MSI MPG A850G PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($229.00 @ Amazon Australia)
Monitor: *LG 32GP750-B 31.5" 2560 x 1440 165 Hz Monitor  ($419.00 @ Centre Com)
Total: $4373.00
Generated by PCPartPicker 2023-08-18 13:22 AEST+1000
A better look at those components.
https://www.lg.com/us/monitors/lg-32gp750-b-gaming-monitor
https://www.msi.com/Power-Supply/MPG-A850G-PCIE5
https://rog.asus.com/motherboards/rog-strix/rog-strix-b760-a-gaming-wifi/
https://www.intel.com/content/www/us/en/products/sku/230490/intel-core-i713700-processor-30m-cache-up-to-5-20-ghz/specifications.html
https://www.deepcool.com/products/Cooling/cpuliquidcoolers/LS720-WH-High-Performance-360mm-Liquid-CPU-Cooler-1700-AM5/2022/15985.shtml
https://www.gigabyte.com/Graphics-Card/GV-N4080AERO-OC-16GD#kf
https://lian-li.com/product/lancool-216/
https://linustechtips.com/topic/1526960-advice-for-pc-build/#findComment-16096729
Yeah, i know. Big fucking bummer. I personally would go to sell it or refund it for that GP750. The only 4K144 card that dont need to play on muddy textures right now are luckily overclocked 7900XTX and 4090.
CPU: Intel Core i7-13700 2.1 GHz 16-Core Processor  ($599.00 @ BPC Technology)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  ($88.00 @ Centre Com)
Motherboard: Gigabyte B760 AORUS ELITE AX ATX LGA1700 Motherboard  ($299.00 @ MSY Technology)
Memory: Corsair Vengeance 64 GB (2 x 32 GB) DDR5-6400 CL32 Memory  ($345.00 @ Amazon Australia)
Video Card: PNY XLR8 Gaming VERTO EPIC-X RGB OC GeForce RTX 4090 24 GB Video Card  ($2699.00 @ MSY Technology)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  ($185.00 @ PCCaseGear)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($155.00 @ Computer Alliance)
Total: $4540.99
Generated by PCPartPicker 2023-08-18 14:02 AEST+1000
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1526960-advice-for-pc-build/#findComment-16096791
