yesterday i accidentally deleted ( yesterday i tired things for about an hour or 2 then it got kinda late so i powered off the system and left as it was) about 250gb of files from my nas before (when i built my nas i didnt have the money for 2 drives so i just got one with the intension to get a second one later later)  . so i thought it will be easier to work on the nas itself on a linux mint live cd then to do it from my pc . but i dont know how do i import my pool, the only commend that helped is “zpool import -f” and that showed what i know all ready is that i have 2 drives connected one of them is my nas's boot pool and the other is my main pool. i dont know what to do from here im very not familiar with zfs (truenas is my fist time using zfs) so im kinda stuck. any help would be appreciated
https://linustechtips.com/topic/1526326-help-with-mounting-zfs-disk/
Did you also put the Poolname behind the command?
For example I used this Command to import a Z-Pool inside Proxmox, that was used in another Poxmox-Server:
zpool import -f POOLNAMEHERE
My Gaming PC:
Inno3D iChill Black - RTX 4080 - +500 Memory, undervolted Core, 2xCorsair QX120 (push) + 2xInno3D 120mm (pull)
AMD Ryzen 7 7800X3D - NZXT x72
G.SKILL Trident Z @6000MHz CL30 - 2x16GB
Asus Strix X670E-E Gaming
1x500GB Samsung 960 Pro (Windows 11 + 10)
1x2TB Kingston KC3000 (Games)
1x1TB WD Blue SN550 (Programs)
1x1TB Samsung 870 EVO (Programs)
Corsair RM-850X + native 12VHPWR-Cable
Lian Li O11 Vision
Alienware 360 HZ QD-OLED AW2725DF, MSI Optix MAG274QRFDE-QD, BenQ ZOWIE XL2720
Logitech G Pro Wireless Superlight 2
Wooting 60HE
Audeze LCD2-C + FiiO K3
Klipsch RP600-M + Klipsch R-120 SW
My Notebook:
MacBook Pro 16 M1 Pro - 16GB
Proxmox-Cluster:
  • Ryzen 9 3950X, Asus Strix X570E F-Gaming, 4x32GB3200MHz ECC, 2x 512GB NVMe ZFS-Mirror (Boot, Testing-VMs + TrueNAS L2ARC), 2x14TB ZFS-Mirror + 1x3TB (TrueNAS-VM), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i7 8700k delidded undervolted, Gigabyte Z390 UD, 4x16GB 3200MHz, 2x 360GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i5 4670, 3x4GB + 1x8GB 1600MHz, 2x 240GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
Proxmox-Backup-Server:
  • i5 4670, 4x4GB 1600MHz, 2x2TB ZFS-Mirror, 2,5G NIC
