My first real build !
TrunkMonkey
Specs:
Gigabyte Z790 Aorus Elite AX
I5 12600K
32 GB Kingston Fury DDR5 5600
Gigabyte RTX 3060TI OC
1 Kingston KC3000 NVMe SSD 1 TB - Boot drive with windows 11 Pro - and for programs like Adobe and such.
2 x Gigabyte Aorus Gen4 NVMe ssd 1 TB each - For games
Deepcool LS 520se CPU cooler
2 x SP140mm Corsair fans front intake fans
1 x AF120mm Corsair back exhaust fan
Corsair CX750F RGB PSU
Corsair 4000D Airflow case
Screens:
Samsung Odyssey G6 S32BG650EU
Lenovo Thinkvision 27"
What do you all think, also is there anything else you guys would recommend me to add or change ?
I am strongly considering to upgrade to the 5000D Airflow case
 You've made solid choices for the CPU and GPU. However, I'd recommend getting a Z690 motherboard instead of Z790. There's minimal performance difference between the two, especially since you're not using a 13th gen CPU. Other than that, your build looks great!
